Modifier Box Resizing Mechanic
dlinders
(@dlinders)
I think it would be better if the modifier blocks and support enforcer blocks would not get bigger or smaller on both sides when resizing. It is hard to place them precisely when you need to position the center exactly right. iIt would be better for it to be pulled to get bigger but only one side moves while the other stays stationary. This would make custom supports easier to place and not allow for easier positioning without having to resize and move then resize and move multiple times. Just place one side were you want it and them drag the other side until its as long as you need it. This also really helps the vertical direction because I have issues when placing custom supports and then when I resize the z axis the block extends upwards and downwards and goes through the build plate. I then have to drag it upwards and reposition it. It would be much faster to place the bottom where I want and then just drag the top up to where I need it with the bottom staying in the same place.
This topic was modified před 5 years by dlinders
Napsal : 16/11/2020 4:42 am
RE: Modifier Box Resizing Mechanic
I would recommend you ender a suggestion on Github.
Napsal : 28/11/2020 7:09 pm
Doesn’t need to do that suggestion as that’s already possible.  I’m not at the pc at the moment but if you hold either control or shift (can’t remember which one) it pulls out that side only.
It’s in the manual on the Prusa knowledge base for Slicer.
Napsal : 28/11/2020 7:46 pm
