MK3S+ bed vibrates violently with PrusaSlicer generated gcode, but fine with Cura generated gcode
Xiaotian Guo
(@xiaotian-guo)
I was printing a few spare parts for my MK3S+ using PrusaSlicer v2.5
Everything seemed working swimmingly until I started to print the parts included Y axis rod holders, I noticed when the nozzle was on these Y axis rod holders, the bed started to vibrate fairly intensely. I stopped the printing as I was worried it would damage the printer.
To isolate the problem I created a new slicer job with just 2 instances of the y-axis rod holders, one rotated 90 degree just in case the orientation was a factor. I started printing and sure enough - when the nozzle was in the open circle area (likely perimeters) which hugs the rod, the speed of x/y axis movement slowed significantly and the vibration started again. I watched it doing this for 2 layers and this happened on both parts with the circle.
I was completely puzzled - shouldn't that circle be a perfect easy thing for the printer steppers? on both X and Y axes you have a perfect smooth sine wave movement - very gentle acceleration/deceleration. Where is the vibration come from???
I then started to monkey around, including moving the parts to different locations on the bed, and try different settings in slicer, like acceleration control, speed, perimeter generation, etc. Same problem.
I then fired up Cura, tweaked settings to match the speed settings in PrusaSlicer and the printer glide through these circles completely silent.
Is this a bug in PrusaSlicer or there I some settings that caused this behavior?
Thanks in advance!
Publié : 22/11/2022 6:34 am
Try changing the infill pattern.
Publié : 22/11/2022 10:52 am
RandyM9
(@randym9)
RE: MK3S+ bed vibrates violently with PrusaSlicer generated gcode, but fine with Cura generated gcode
+1
What @diem said.
Personally, I find the gyroid infill in particular causes my print bed to shake, rattle & roll, so I avoid it. I much prefer 3D honeycomb which will provide similar strengths and print times as gyroid with much less shaking.
Cheers
Publié : 23/11/2022 5:24 am
I suspect that Cubic may be the better fill for that part but the important thing is to change the fill and see if the vibration changes.
Publié : 23/11/2022 6:51 am
