Missing model structure.
MaxDuracell
(@maxduracell)
I'm trying out PrusaSlicer and I'm really liking the print quality I get from it, but I've just noticed an issue with how the slicer is interpreting stl files. I'm in the process of printing out a RC airplane, and the designer has created a volume with modeled infill structure.  When I slice it, the interior pieces of the volume are removed leaving a large unsupported area.  Cura seems to handle these areas just fine.  Is there a setting I'm missing to get these areas back?  If you'd like to have a look at the files yourself, they can be found here:
https://cults3d.com/en/3d-model/various/rc-plane-eclipson-model-a-free-version-by-eclipson
The fuselage in particular is what I'm looking at.  Part Fuse2 or Fuse3.
Ce sujet a été modifié il y a 5 years par MaxDuracell
Publié : 13/02/2021 1:10 pm
RE: Missing model structure.
Hi Max,
Which bits are missing?
Publié : 13/02/2021 2:16 pm
MaxDuracell
(@maxduracell)
Thanks for your reply!  Under the deck there are supposed to be ribs running the length of the part. as well as a vertical support in the center.
Publié : 13/02/2021 2:24 pm
@maxduracell
Hi Max,
More like this then!
Try changing the setting marked below...
Publié : 13/02/2021 2:58 pm
By the way, "Fus2_wo_LG.STL", has errors in the file, and would be best repaired with netfabb.
Publié : 13/02/2021 3:02 pm
MaxDuracell
(@maxduracell)
Yep.  That did it.  Thank you!  I couldn't say about the errors.  I might have to take a look at netfabb later.  These aren't my files, but maybe I'll learn something along the way.
Publié : 13/02/2021 3:32 pm
Jakub Dubielis
(@jakub-dubielis)
Membre
I have a similar situation, unfortunately the resolution hack do not work. Any other ideas?
Publié : 29/06/2024 1:55 pm
Could you share the project file including your settings,so far,and the model files. Could you also advise which version I prusa slicer you are using.
Note. The project file must be zip compressed or the forum will not attach the file. Regards Joan
Publié : 29/06/2024 3:23 pm
Jakub Dubielis
(@jakub-dubielis)
Membre
 The project and settings in the attachement. I am using Prusaslicer 2.8.0. config eagle
kind regards,
Kuba
Publié : 30/06/2024 5:45 am
Jakub Dubielis
(@jakub-dubielis)
Membre
Any luck with the files?
Publié : 21/07/2024 8:33 pm
Sorry,
No
Joan
Publié : 21/07/2024 11:00 pm
