Maximum printing height on customprinter
Hey,
i have a custompinter with a printheight of 1750 mm. In Prusasclicer(2.5.0) it´s only possible to go up to 1200mm. In an older version(2 years ago or so) it was possible. At the Moment I can´t print high objects. Would be cool, if it would be possible again to config bigger printer. TIA
Veröffentlicht : 18/09/2022 6:39 pm
RE: Maximum printing height on customprinter
Try SuperSlicer it will allow you to do this, the latest stable version is based on PrusaSlicer 2.4, so you'll get that functionality, and more. You will have to familiarize yourself with SuperSlicer it's not exactly the same as PrusaSlicer. It has many more options. If your building custom printers you should have no issue learning it.
Veröffentlicht : 19/09/2022 12:19 am
