Filament Usage Calculation Not Being Shown In Prusa Slicer when using Multi Filament Single Extruder
Christopher Rossi
(@christopher-rossi)
I just started experimenting with multi filament and for some reason after slicing I see nothing but 0.00 for each. It is not showing how much of each material is going to be used for the print. Is there something wrong with my install or settings? Not knowing how much of each filament is being used for the print makes things slightly more complicated. Thank you.
Best Answer by Neophyl:
Check your filament profile has the density filled in.  It cant work out weight and therefore cost without all fields being filled in.
Veröffentlicht : 12/07/2023 11:46 am
RE: Filament Usage Calculation Not Being Shown In Prusa Slicer when using Multi Filament Single Extruder
Veröffentlicht : 12/07/2023 12:07 pm
Christopher Rossi
That makes sense. I will have to look again at that later. I will let you know. Thank you.
Veröffentlicht : 12/07/2023 12:12 pm
Christopher Rossi
That seems to be it. Thank you.
Veröffentlicht : 13/07/2023 2:15 pm
