Manually define perimeter ordering?
DietmarSchwertberger
(@dietmarschwertberger)
Hi!
I have a problem with the perimeters that PrusaSlicer 2.6.1 is creating.
For mechanical stability, I would need the thin wall printed in one go with the outside perimeters. The wall is a kind of spring:
Sliced, w. infill     Printed
I.e. basically I would need first the paths that "Spiral Vase" setting is generating and then the inner walls and infill:
with "Spiral Vase" setting
Is there a way to accomplish this? Using "External perimeters first" did not help and "Spiral Vase" is not really an option.
Regards,
Dietmar
Posted : 11/11/2023 3:34 pm
RE: Manually define perimeter ordering?
Not that I am aware of.  Would be happy to be proven wrong but I have found no setting to control this is PS.
Posted : 12/11/2023 11:30 am
I could probably add a modifier (box or custom shape) with a setting to remove the internal perimeter, but that does not scale up well...
Posted : 12/11/2023 3:24 pm
The mesh modifier does not help. Setting "Perimeters" to 0 does affect the minimum, but the slicer will still generate perimeters and I still have the gap.
mesh modifier box added with "Perimeters" set to 0
I have also tried "Perimeter generator: Classic" with "Detect thin walls"  instead of "Arachne", but that does make the gaps even worse.
Posted : 12/11/2023 4:23 pm
Probably the only way to accomplish this is to create the GCODE programatically, e.g. using FullControl:
https://github.com/FullControlXYZ/fullcontrol
Posted : 27/04/2024 5:48 pm
