Manually define perimeter ordering?
Hi!
I have a problem with the perimeters that PrusaSlicer 2.6.1 is creating.
For mechanical stability, I would need the thin wall printed in one go with the outside perimeters. The wall is a kind of spring:
I.e. basically I would need first the paths that "Spiral Vase" setting is generating and then the inner walls and infill:
Is there a way to accomplish this? Using "External perimeters first" did not help and "Spiral Vase" is not really an option.
Regards,
Dietmar
RE: Manually define perimeter ordering?
Not that I am aware of. Would be happy to be proven wrong but I have found no setting to control this is PS.
I could probably add a modifier (box or custom shape) with a setting to remove the internal perimeter, but that does not scale up well...
The mesh modifier does not help. Setting "Perimeters" to 0 does affect the minimum, but the slicer will still generate perimeters and I still have the gap.
I have also tried "Perimeter generator: Classic" with "Detect thin walls" instead of "Arachne", but that does make the gaps even worse.
Probably the only way to accomplish this is to create the GCODE programatically, e.g. using FullControl:
