Manual Support Interface out of other material (PETG)
Interspieder
(@interspieder)
Hi!
I am using a single extruder printer and want to manually change the filament for the support interface layer as seen in this german video (but on a bambu lab printer).
I searched the internet and managed to set the material change rudimentary and it's working, but not perfectly yet.
I am running into the issue, that during and after filament change, the temperature setting (and I assume the other filament settings aswell) does not get adjusted to the new filament inserted (even though assigned in Prusa Slicer accordingly).
For example, if I print the main part and the support structure out of PLA (195°C) and the interface layer out of PETG (230°C) the temperature does not get adjusted to PETG during purge and printing of the interface layer - it stays at 195°C.
My custom tool change G-Code looks like this:
M600
R109
G4 P5000
Ideally, the logic would look something like that, but I have no idea how to realize this in GCode.
Cold (PLA) -> Hot (PETG)
Filament Change (works already) -> eject PLA at cold temp -> wait for hot filament temp stored in filament settings (profile selected for extruder 2) -> insert PETG for interface layer -> purge at hot temp-> continue print
Hot(PETG) -> Cold (PLA)
Filament Change (works already) -> eject PETG at hot temp -> insert PLA at hot temp -> purge at hot temp -> wait for cool down to filament temp stored in filament settings (profile selected for extruder 1) -> continue print
Any tips? Many thanks in advance!
Napsal : 05/10/2023 10:04 pm
