"Manual Mutimaterial" no longer supported?
Hey, I always used the "Single Extruder Multi Material" setting with an added M600 command in the custom gcode section "Tool Change" section. Worked perfectly fine on the MK4s but on my Core One there is always a massive layershift after the first layer when it includes fillament changes. I had hoped this would be fixed in the firmware but no luck so far. Finally contacted Prusa support about it and was told that this is not an intended sue and as such no supported. I always thought this was the office way to make this work. Does this still work for anyone with a Core One?
Napsal : 23/11/2025 8:50 pm
