Manual control of the infill combining
SPTNQ.com
(@sptnq-com)
Hi there
I am having a print where I want the infill on each layer done for 0-0.84mm, then the infill should be combined for two layers. How can I set this up?
Respondido : 18/01/2023 8:51 am
RE: Manual control of the infill combining
Just use a height range modifier.
Right click on the part and add the height range modifier from the context menu.  Then you adjust the range of the modifier to cover the heights you want.  You can then add the settings you want to modify.  So in the right hand tree panel click on the height range modifiers cog icon.  The select Add Settings (Not Infill).  When you select Add Settings it displays a list of ALL the available modifier settings.  Form this list you now select Infill.  That will bring up the full range of infill settings, of which combine infill every x layers is one.
Respondido : 18/01/2023 9:09 am
SPTNQ.com
(@sptnq-com)
Got it! Thanks master!
Respondido : 18/01/2023 9:46 am
