Make surfaces "mesh" with modifier and infill - unwanted "bridgelines" on the corners
[Rozwiązany] Make surfaces "mesh" with modifier and infill - unwanted "bridgelines" on the corners
Bastian
(@bastian-2)
Hi there,
i modelled a bottom plate for a Topton N305-Server, which should be "holed" for air ventilation.
So i added a box as modifier, set bottom and top layers to zero and played with the infill-type and %. It works as expected, but i have some bridge infill-lines (blue ones) on the edges (between modell and mesh), that looks bad.
How to get rid of them?
Thanks in advance,
Bastian
Best Answer by Bastian:
I solved it - hat to set the bottom plate to 100% infill; then the modifier to xx%.
Opublikowany : 25/07/2025 5:00 pm
Bastian
(@bastian-2)
RE: Make surfaces "mesh" with modifier and infill - unwanted "bridgelines" on the corners
Opublikowany : 25/07/2025 5:07 pm
