Make it more obvious to change the Extruder for each part.
Yimir
(@yimir)
Just finished getting the MMU2s built and calibrated. We wanted to do a simple 2 color print to test. But boy there's not easy instructions on how to do this in the new PrusaSlicer 2.0.0.
Maybe i'm just unfamiliar and a novice with the MMu2. But it took me a min to figure out I need to add the 2nd part as a part or a modifier rather than just dragging it in.
On top of that the first part the Extruder could easily be changed by right clicking on the object. The new objects. NOPE. Took me 30 mins of frustration to figure out I could double click on the Extruder column value to allow me to Change the Extruder value...
Can we please get some tutorials on this? And maybe make it more obvious that you can change a value in the list of parts.. Even make it more consistent to where you can right click to change the Extruder value.
This topic was modified 7 years temu by Yimir
Opublikowany : 18/08/2019 7:18 pm
2 ludzie polubili
Bazzalight
(@bazzalight)
RE: Make it more obvious to change the Extruder for each part.
Totally agree how non intuitive the extruder selection currently is. I find I need 2 clicks as opposed to a double click to bring the menu up. A right click on the part object would be a lot simpler or even a selector indicator to show there is a sub menu.  Perhaps a fix will come.
Opublikowany : 15/09/2019 3:22 am
