Machine limit control
qwewer
(@qwewer)
Is there a way to not include machine control commands (M201, M203, M204, M205) in the gcode files that PrusaSlicer makes? Without manually deleting it form the gcode file, of course.
Opublikowany : 28/06/2020 6:00 pm
RE: Machine limit control
Posted by: @cool-kornel
Hello and welcome in Prusaforum!
You could make special changes to the gcode with a post processor script:
http://projects.ttlexceeded.com/3dprinting_prusaslicer_post-processing.html
However, programming knowledge in perl, python or similar is required.
Opublikowany : 28/06/2020 11:18 pm
qwewer polubić
Instead of selecting Marlin as your gcode type choose rep rap instead. That will then not include the codes but otherwise the content is the same.
Opublikowany : 29/06/2020 12:06 am
qwewer polubić
qwewer
(@qwewer)
@neophyl
Just what I needed, it only removes those lines/commands. Thank you.
Opublikowany : 29/06/2020 8:26 am
