Machine Crash when Moving Between Sequental Objects
thegraylacke
(@thegraylacke)
Membre
PrusaSlicer 2.8.1, 2HXLIS 6.2.0
When moving between different parts while printing in sequential mode, my print head plowed through an already printed part on its way to the next one. I have already updated the Extruder Clearance to match the XL (R65 H20). I had assumed that the printer would return to a rapid plane of Z20 (to match the extruder clearance value) when moving between parts, but this is not the case. You can see in the screenshot how the rapid move goes right through a part.
(from the ring in the back right, through the bar, to the ring at the front)
Is there a hidden setting I've missed for a raised rapid plane between parts? I have tried adding some Z moves to the Between objects G-code area of Printer-> Custom G-code, but with no success.
Publié : 20/10/2024 7:37 pm
