M600, what commands are included in the color change command and is there a way to insert my own commands
Getahobbie
(@getahobbie)
When I use M600 (on my mini) the tip has a wispy bit at the end that deposits bits into the extruder as the filament comes out.
Is there a way that I can remove the "M600" command from the custom gcode section and just put in all the regular M600 commands and add my own so that the tip is shaped without wispiness?
Opublikowany : 10/06/2021 10:20 pm
