M600 and File Change
SnowEagle
(@snoweagle)
I want to print 3 separate files each 3mm high and each a different color. The first file (white) has openings that the other 2 fit into, both printed in a different color. (Blue & Red)
Is there a way to use M600 at the end of the first file, change color, then select the next file to print that fits into the first? Then repeat the process for the third file.
Respondido : 14/01/2021 11:19 pm
fe60
 fe60
(@fe60)
RE: M600 and File Change
I guess you are using Sequential printing [1]. To change the filament between the objects, just make M600 the "Between objects G-code" (Printer Settings=>Custom G-code)
[1] https://help.prusa3d.com/en/article/sequential-printing_124589
Respondido : 18/01/2021 7:39 am
