Lost print settings/changed print settinga
saulquinn
(@saulquinn)
Mitglied
Hello,
I opened a 3mf file and it changed the profiles on prusaslicer.  It now shows what is seen in the screenshot which are all notably slower than the original profiles.  I also lost my custom filament and print settings profiles.  I did try reinstalling prusaslicer.
What happened and how can I fix it?
Thanks!
Veröffentlicht : 10/03/2024 5:58 pm
RE: Lost print settings/changed print settinga
If you open a 3mf file it will temporarly load the printer profile and the print profile used when it was created. But when you exit Prusaslicer it should go back to default. If you reinstalled Prusaslicer—for which there really shouldn't be a reason—and you think these profiles are "slow", I guess you had the input shaper profiles installed before. Go to Configuration>Configuration Assistant, and reimstall the Input Shaper printer profile(s).
Veröffentlicht : 10/03/2024 11:08 pm
