Looking for a Dremel 3D45 profile for Prusa Slicer... Help me help my students!
scotts
(@scotts)
Hi, I was gifted a Dremel 3D45 printer for my classroom recently.  Current printers are Prusa Mini and Prusa MK3S.  I would like to be able to use the Dremel printer too, and use the Prusa Slicer - as it is especially advantageous at colour changes at given layers.  Does anyone have a profile / configuration that produces good results?  Cheers from Aussie Land.
Respondido : 14/08/2021 6:22 am
Elephantmotor
(@elephantmotor)
RE: Looking for a Dremel 3D45 profile for Prusa Slicer... Help me help my students!
I have just made a profile, let me know if it works for you.
https://github.com/elephantmotor/Prusa-for-3D45/releases/download/V1.0.0/3D45.zip
Respondido : 14/01/2022 10:58 pm
scotts
(@scotts)
 Hi Mate!  Thanks.  I've only just seen this and done a test print.  It worked well.  I'll play around some more and see how Dremel handles Prusa commands like a colour change.  Much appreciated!  Scott
Respondido : 15/04/2022 8:29 am
RAH1
 RAH1
(@rah1)
@Scotts @Elephantmotor
Does anyone have an update?  Did the profile work well with the added features of Prusa Slicer?  How about variable layer height?
Does anyone have the referenced Dremel_3D45_platform.stl?
Thank you,
RAH
I am the inveterate tinkerer. I can tink up most anything.
Respondido : 24/08/2022 2:19 pm
RAH1
 RAH1
(@rah1)
Posted by: @rah1
Thank you,
RAH
I found the Dremel STL file in the Dremel install of Cura.  Moving it to a more useful place for the ini file.  I will let you know how that works out.
RAH
Respondido : 24/08/2022 2:43 pm
Camille Lamkin
(@camille-lamkin)
Miembro
Hello,
I am in the same situation as @scotts. I am already very well versed in Prusa Slicer, and I also just really don't like the Dremel DigiLab Slicer, so I was excited to see that someone had already made a profile for the Dremel 3D45 (my school got a Dremel 3D40, but since the only difference between the two is being able to use multiple filaments vs just PLA, the profiles should be compatible).
However, after I downloaded the profile that @Elphantmotor created and followed the steps on the Prusa page on manually downloading profiles, I kept getting an error message in the configuration wizard saying it "failed to extract local archive" for the 3D45.zip. I've tried doing this multiple times and still keep getting the error message, so I can't figure out what is going wrong.
Can someone please help?
Thanks
Esta publicación ha sido modificada el hace 1 year por Camille Lamkin
Respondido : 29/07/2024 9:15 pm
RStay
(@rstay)
Miembro
Hello, anyway you would be willing to make a Prusa Slicer profile for a Dremel 3D20 ?  Or can the one for the 3D45 be used for the 3D20 as well ?
Respondido : 28/11/2024 10:58 pm
Elephantmotor
(@elephantmotor)
Extract the .ini file from the zip and use File>Import>Config to load files.
Here's the link for the .ini file and the .stl
https://github.com/elephantmotor/3D45-Profile-for-PrusaSlicer
Respondido : 24/01/2025 5:44 pm
Elephantmotor
(@elephantmotor)
platform .stl is here:  https://github.com/elephantmotor/3D45-Profile-for-PrusaSlicer
