Linux PrusaSlicer 2.8.1 requires glibc-2.36 - not in earlier Linux versions
[Rozwiązany] Linux PrusaSlicer 2.8.1 requires glibc-2.36 - not in earlier Linux versions
sbixby
(@sbixby)
I run Ubuntu 22.04; I'm not OK to upgrade to 24.04 because I develop commercial software targeting 22.04 and I've run into library issues in the past.
I went to update to Slicer 2.8.1 appimage, which requires glibc-2.36, but this is not available in Ubuntu 22.04 unless I build from source, which comes back to my first point.
Anyone have any thoughts?  If I had time I'd poke around the source and see if glibc-2.36 is actually required...
Best Answer by _KaszpiR_:
I remember there are two app image files, did you try both of them?
Opublikowany : 04/10/2024 8:32 pm
_KaszpiR_
(@_kaszpir_)
RE: Linux PrusaSlicer 2.8.1 requires glibc-2.36 - not in earlier Linux versions
Opublikowany : 05/10/2024 8:00 am
For some reason the dev's were keen to remove perl code and broke a lot of linuxes in the process.  They haven't provided an arm build so Raspberry Pi users are left adrift too.
Opublikowany : 05/10/2024 4:43 pm
sbixby
(@sbixby)
 Ah, shoot.  I'm embarrassed to say that didn't even occur to me that the older/newer named appImage files were for this reason.
Thanks!
Opublikowany : 07/10/2024 1:32 pm
