Linear Advance Question
Qlmmy
(@qlmmy)
I am looking for some clarification.
I was looking through my gcode and I saw two M900 commands back to back.
M900 K0.03 ; Filament gcode LA 1.5
M900 K30 ; Filament gcode LA 1.0
Why are there two? Wouldn't the second one cancel out the first?
Best Answer by bobstro:
Just to add to Joan's answer. Prusa recently migrated from Linear Advance v1.0 (LA1.0) to v1.5 (LA1.5). LA1.5 uses a range of values well below 2, while LA1.0 values tend to be 10 or higher.
Prusa built some smarts into the new firmware to recognize the difference. If a LA1.5 value is seen in the gcode, it is used. If both exist, the LA1. 5 setting is used. If only a LA1. 0 value is seen, it is translated to a LA1. 5 equivalent.
Meanwhile, the approach of providing both values is for backwards compatibility with older firmware. As you suspected, the last value is used for the remainder of the print. On a printer running older firmware, the same gcode will work as expected.
Veröffentlicht : 09/12/2020 10:20 pm
RE: Linear Advance Question
Hi Qlmmy
one value
is for LA 1.0 the other
Is for LA1.5
I believe
LA 1.0 ignores the LA1.5 value, and
LA1.5 Igores the LA 1.0 value
I trust that that makes sense for you
Regards Joan
Veröffentlicht : 10/12/2020 12:41 am
Veröffentlicht : 10/12/2020 3:08 am
