Limit Dovetail cut area
Kboruff
(@kboruff)
I realized after modeling that I can't just cut one part of the model with the dovetail. it's instead a planar cut that also chops through the top of the platform on the left in this image.
Is there a way to limit the cutting area or explicitly protect the platform of the model with a modifier or something? I've rotate the cut at a 45 but it makes printing a much more complicated process.
Opublikowany : 08/06/2025 11:28 pm
BaconFase
(@baconfase)
RE: Limit Dovetail cut area
You can rightclick on the part(s) that you want to swap to the other color.
Opublikowany : 10/06/2025 1:43 am
Kboruff
(@kboruff)
I just tried right clicking but that didn't do anything on the object about to be cut. Do you mean after it's cut?
Opublikowany : 10/06/2025 2:28 am
The partial cut on dovetails is not possible, it only works with a flat cut. There’s already an open issue on  the PS GitHub for it.
Opublikowany : 10/06/2025 4:53 am
1 ludzie polubili
