Limit Dovetail cut area
I realized after modeling that I can't just cut one part of the model with the dovetail. it's instead a planar cut that also chops through the top of the platform on the left in this image.
Is there a way to limit the cutting area or explicitly protect the platform of the model with a modifier or something? I've rotate the cut at a 45 but it makes printing a much more complicated process.
RE: Limit Dovetail cut area
You can rightclick on the part(s) that you want to swap to the other color.
I just tried right clicking but that didn't do anything on the object about to be cut. Do you mean after it's cut?
The partial cut on dovetails is not possible, it only works with a flat cut. There’s already an open issue on the PS GitHub for it.
