Light tight walls
I print pinholes and I recently discovered that the surface on the bed, is not light proof. It seems porous, so the light comes in the camera. Vertical walls are ok, though.
General thickness on the camera body is 3mm and these wall are completely filled. Cameras have various dimensions and I noticed that the small camera is almost ok (very few "holes" if none) but for bigger cameras that's a problem.
To avoid this I add an enforcer and decreased the speed of the infill for the 3mm of the body and imposed 100% infill for these 3mm...but still is not perfect.
Another idea would have been to increase the multiplier just for the first few layers but I could not find it.
Any suggestions?
Thanks,
Andrea
Opublikowany : 13/02/2023 4:38 pm
