Layer Shifting only on one model from three which were printed at the same time
Project6g
(@project6g)
Hello, as you can see in my topic I have experienced a weird issue.
I have sliced 3 models the two were printed fine but the one had a significant layer shift, almost 8 mm which was the thickness of the part.
The bed adhesion was great and the part did not move from the bed, so I assume this could be a software issue as the other parts on the same layer were spot on.
Has anyone experienced a similar issue?
Prusa Slicer 2.8
Posted : 13/09/2024 2:24 pm
RadekP
(@radekp)
RE: Layer Shifting only on one model from three which were printed at the same time
you can try this
Enable "Steeper ramp before obstacles" (printer/extruder configuration) by default - when disabled unpredictable crashes/layer shifts occur #13235
see https://github.com/prusa3d/PrusaSlicer/issues/13235
r
Posted : 13/09/2024 8:25 pm
Project6g
(@project6g)
Sorry for the late reply and thank you for you response I will try this as well. Once I was printing single parts everything was fine but with mutliple parts I had the shift only on 1 model of the 4.
Please note that on the layer where the shift was experienced 3 models were still building, yet the shift affected only one of them and the bed adhesion was solid with a relatively wide brim.
Posted : 03/10/2024 8:35 pm
RD
 RD
(@rd-5)
This is still an issue, and on the XL, this setting worked for me and eliminated collisions. I could actually see the bed moving up and down, I guess "hopping", when compared to the previous print that failed.
Posted : 22/01/2026 11:59 pm
