Layer Shifting only on one model from three which were printed at the same time
Hello, as you can see in my topic I have experienced a weird issue.
I have sliced 3 models the two were printed fine but the one had a significant layer shift, almost 8 mm which was the thickness of the part.
The bed adhesion was great and the part did not move from the bed, so I assume this could be a software issue as the other parts on the same layer were spot on.
Has anyone experienced a similar issue?
Prusa Slicer 2.8
Posted : 13/09/2024 2:24 pm
RE: Layer Shifting only on one model from three which were printed at the same time
you can try this
Enable "Steeper ramp before obstacles" (printer/extruder configuration) by default - when disabled unpredictable crashes/layer shifts occur #13235
see https://github.com/prusa3d/PrusaSlicer/issues/13235
r
Posted : 13/09/2024 8:25 pm
