layer pattern not coming out right.
Saumya Agarwal
(@saumya-agarwal)
Membre
Hello. I have recently started 3d printing and I am unable to get this right. The bottom layer pattern isn't coming out fine in some places, as shown in the picture. I have an open top and the bottom shell is 1.4 mm thick with a monotonic pattern, with no infill.  Is there something that I am missing? Thank you.
Publié : 25/08/2024 9:32 am
RE: layer pattern not coming out right.
The picture seems to be missing
Joan
Publié : 25/08/2024 3:51 pm
Everything is going to be wild guesses without more data. If you upload your project as a 3mf file, you're likely to get better advice grounded in data. A 3mf file contains your STL but most importantly also ALL your settings.
In PrusaSlicer, go to File/Save project as, to create the 3mf file. Zip-compress it to turn it into a .zip file (right-click Compress on Mac and Win11, right-click Send to/Compress on Win 10). Attach the zipped file a post on this forum using Attach file below the text edit box. It has to be a zip file, or the forum software will silently reject it.
Publié : 25/08/2024 6:27 pm
Saumya Agarwal
(@saumya-agarwal)
Membre
I hope the image is visible now.
Publié : 26/08/2024 11:29 am
no image
Publié : 26/08/2024 2:33 pm
Joan, I can see the images.
Publié : 26/08/2024 2:35 pm
fabnavigator
(@fabnavigator)
Sorry. No images have been attached to this thread.
Publié : 26/08/2024 7:25 pm
_KaszpiR_
(@_kaszpir_)
Instead of choosing 'Attach file's on the bottom, use 'Add Media' on the top of the input window. It will show upload section and you can upload and then select media to put into the post - this works best.
Publié : 27/08/2024 6:21 am
Robin
(@robin)
Posted by: @foxrun3d
what he said...
Publié : 27/08/2024 9:38 am
