[Rozwiązany] Layer orientation
Romain Harter
(@romain-harter)
Layer orientation
I am wondering if there is a way to change layer orientation in PrusaSlicer?
To improve adhesion without using supports I would need to change orientation of the blue surrounded zone above. Best would be to set a 90° offset to have the layer fixed to the existing hedge like the non-surronded part.
Hope it is clear!
Best Answer by Neophyl:
Right click an object, there’s quite a few types to choose from. You can also set different settings per object that way.
If you aren’t familiar with the basics like modifiers then you should really go visit the Prusa Slicer knowledge base and do a bit of reading.  https://help.prusa3d.com/category/prusaslicer_204
Opublikowany : 02/10/2022 7:57 pm
RE: Layer orientation
Sure there is. Print Settings->Infill->Advanced->Bridging angle
Opublikowany : 05/10/2022 4:45 pm
towlerg
(@towlerg)
.... I would need to change orientation of the blue surrounded zone above
Just the area enclosed in the blue line while leaving other bridging in current orientation?
Opublikowany : 06/10/2022 11:28 am
Sorry, I misunderstood. To do this only in that region, you'd have to add a modifier to cover that area, then right-click it→Add Settings→Infill→Bridging angle.
Just a quick PoC example:
I hope that's similar to what you're trying to accomplish.
Opublikowany : 06/10/2022 12:05 pm
1 ludzie polubili
Romain Harter
(@romain-harter)
Seems to be exactly what I need but, how do you add a "Modifier" ? Didn't find the option
Opublikowany : 07/10/2022 6:45 am
Opublikowany : 07/10/2022 7:34 am
Romain Harter
(@romain-harter)
Awsome! Thank you
Opublikowany : 15/10/2022 10:56 am
