Knowledge & Best practices for "Single extruder MM setup"
Hello
I like Prusa Slicer , and multi color prints ..
I have a Zonestar Z9V5pro ( switching hotend 4 in 1 ). and currently use some gcode lines in the "tool change gcode" but would like to fully switch to the MM Setup values / usage
Am I supposed to find the values set in "cooling tube position" and "filament parking position" in the generated gcode ?
( seems it's not used to unload the current filament , do not see G1 E- values or something close )
For machines as the one I have , what's the good way ( best pratice ) for the initial load of the first filament , and unload before the next filament load ?
Thanks
PS : I read quite some doc & info about MMU and filament changes , but have not found those answers.
Posted : 26/09/2023 11:32 am
