Keeping print direction consistent
Rob Meades
(@rob-meades)
Hi there. I am printing a circular belt, vertically, in PLA for use in a music box.  Everything works fine except that, on one layer, a layer that has more holes in it than any of the others, Prusa Slicer decides to change the direction of the print and this leads to issues, see images below.
Is there a setting I can tweak in my Prusa Slicer configuration to stop the print changing direction in this way?  FYI, I've tried halving the print speed (manually on the MK4S printer) but the fault still occurs.
 Belt Belt on build plate
Fault area Fault area
Best Answer by jan.d.slay:
Try not to exceed 50 mm/s for all layers (except the first layer).
You can also set the fan speed to 100% so that the single line loses temperature quite quickly.
Napsal : 09/02/2026 12:14 pm
Rob Meades
(@rob-meades)
RE: Keeping print direction consistent
To clarify, here is a view in Prusa Slicer with "show travel" on: it is the criss-crossings in blue that I would like to avoid, I want just the nice [hidden 'cos they are inside the material] unidirectional circular movements.
Show travel Show travel
Napsal : 09/02/2026 12:50 pm
jan.d.slay
(@jan-d-slay)
Could I take a look at the 3MF in my Prusa Slicer?
Napsal : 09/02/2026 12:53 pm
Rob Meades
(@rob-meades)
Certainly: see attached.
This post was modified před 4 months 2 times by Rob Meades
Napsal : 09/02/2026 12:57 pm
jan.d.slay
(@jan-d-slay)
Napsal : 09/02/2026 1:20 pm
1 lidem se líbí
Rob Meades
(@rob-meades)
OK, giving that a try...
Napsal : 09/02/2026 1:32 pm
1 lidem se líbí
Rob Meades
(@rob-meades)
That has definitely improved things, just a few spots left now.  Is there a speed/fan setting I missed (see below) or should I just try an even lower print speed?  It is not a large print so slower is not a problem.
New speeds New speeds
Fan control Fan control
Remaining faults Remaining faults
This post was modified před 4 months by Rob Meades
Napsal : 09/02/2026 3:20 pm
1 lidem se líbí
Rob Meades
(@rob-meades)
Ah, no, I had the fan on 100% of the time, rather than at 100% power: switching to fan at 100% power did indeed do the trick.
Many thanks for your swift and valuable help!
Napsal : 09/02/2026 8:03 pm
2 lidem se líbí
jan.d.slay
(@jan-d-slay)
Posted by: @rob-meades
You're welcome. I'm glad it was a simple mistake that we were able to fix without much trial and error!
Since it was only a single perimeter, it must rest stably on the lowest line. It cannot be supported on either the left or right. Therefore, it requires as much cooling as possible to maintain its position.
Keep up the good work!
Napsal : 10/02/2026 6:31 am
1 lidem se líbí
