Jak zvednout model.
Bedou Vojtěchovský
(@bedou-vojtechovsky)
Jak zvednout model.
Nedaří se mi zvednout model do vzduchu nad podložku. Prostě nevím jak na to. Když dám model přesunout, vždy se vrátí na podložku. Také jsem zkoušel
zadat pozici Z v manipulaci s objektem a zase se vrátí do přednastavené polohy na podložku. Potřebuji to výš, neb  mezera podpory mezi objektem a  podložkou
je moc malá, aby se podpěry pak daly odstranit. A jiná poloha modelu je vyloučená. Poradíte ?
Best Answer by Sembazuru:
Posted by: @bedou-vojtechovsky
Wrong language forum, but I'll try to be helpful. -- Špatný jazyk fóra, ale pokusím se být nápomocný.
Google Translation of question into English (my only language): -- Překlad otázky do angličtiny (můj jediný jazyk) od Googlu:
How to lift a model.I can't get the model up in the air above the base. I just don't know how to do it. When I move the model, it always returns to the base. I also tried
entering the Z position in the object manipulation and it returns to the preset position on the base. I need it higher, because the support gap between the object and the base
is too small to remove the supports. And any other position of the model is out of the question. Can you advise?
Prusa slicer (at least in FDM mode) will always try to put the full object on the bed. To force your object to float above (and thus have supports generated to support the print), try adding a part to your object to act as the anchor to the bed. For example, add a primitive cube and re-size that cube to 0.2mm on all axes. At this point you may want to make sure the little cube part is on the bed if there is a "Drop to bed" icon to the right of the x/y/z position boxes. Then select the part (or parts) of your original object and move them vertically up in the z axis. The little tiny cube should stay on the bed, and will be too small for the slicer to bother wasting plastic (and extruder moves) on. I hope this helps, and I hope the Google translation makes sense. 😉
Google translation of answer to Czech (just in case you don't read English): -- Překlad odpovědi do češtiny z Googlu (pro případ, že neumíte anglicky):
PrusaSlicer (alespoň v režimu FDM) se vždy pokusí umístit celý objekt na podložku. Chcete-li, aby se váš objekt vznášel nad podložkou (a tím pádem byly vygenerovány podpěry pro podepření tisku), zkuste k objektu přidat část, která bude fungovat jako kotva k podložce. Například přidejte primitivní krychli a změňte její velikost na 0,2 mm na všech osách. V tomto okamžiku se ujistěte, že malá část krychle je na podložce, pokud je napravo od políček pozic x/y/z ikona „Přesunout na podložku“. Poté vyberte část (nebo části) původního objektu a přesuňte je svisle nahoru v ose z. Malá krychle by měla zůstat na podložce a bude příliš malá na to, aby se na ní kráječ obtěžoval plýtvat plastem (a extruder se pohyboval). Doufám, že to pomůže a doufám, že překlad z Googlu dává smysl. 😉
Opublikowany : 16/09/2025 9:17 am
Sembazuru
(@sembazuru)
RE: Jak zvednout model.
See my (limited) designs on:
Opublikowany : 16/09/2025 6:24 pm
1 ludzie polubili
