Issue with PrusaSlice: added layers
benoit_fanchon
(@benoit_fanchon)
Hello,
I'm using PrusaSlicer Version 2.2.0+Win64
I slice a box with 2 areas, and a hole in the middle: Box side view Box top view
After slicing, the central hole if filled and one of the areas is less deep than the other: Sliced side view Sliced top view
I don't understand what could cause this, which looks like a bug to me.
How can I investigate more ? (The model comes from Thiniverse, I can indicate its reference if needed.)
(I'm sorry, I didn't noticed that the first message was incomplete. Any moderator should remove it - or explain me how I could))
Veröffentlicht : 12/04/2020 10:09 pm
RE: Issue with PrusaSlice: added layers
Hi Benoit,
Could you give us the Model Link on  Thingiverse. so we can look at the problem.  Please.
I suspect that the artefact thickness is smaller than the nozzle thickness, or there is an error in the STL.
Veröffentlicht : 13/04/2020 3:43 pm
benoit_fanchon
(@benoit_fanchon)
The file is 'gtb_three.stl' in the following link: https://www.thingiverse.com/thing:332813
Veröffentlicht : 13/04/2020 4:51 pm
Hi Benoit,
Pusa Slicer does not recognise any errors, but  Netfabb does and fixes them.
Attachment removed
Veröffentlicht : 13/04/2020 5:55 pm
Fixed file attached above
Veröffentlicht : 13/04/2020 6:28 pm
benoit_fanchon
(@benoit_fanchon)
Thank you for your quick and efficient answer 🙂
Veröffentlicht : 13/04/2020 11:53 pm
