Issue with bridging
Gilad K
(@gilad-k)
Issue with bridging
The images explain an issue I have with bridging.
Any ideas how to force a bridge infill?
I Also added the project, PrusaSlicer 2.6.1
The notches are for zip-locks if you wonder why.
Issue with bridge
Best Answer by Snuffleupagus:
Slices perfectly in 2.4.2, if your using 2.6.X then turn off Detect Bridging perimeters and you should be fine.
Good Luck,
Opublikowany : 27/10/2023 11:11 am
Snuffleupagus
(@snuffleupagus)
RE: Issue with bridging
Good Luck,
Opublikowany : 27/10/2023 3:57 pm
Gilad K
(@gilad-k)
You are right! It worked.
Opublikowany : 27/10/2023 6:25 pm
