Is it a bug? Big gaps
qqcs
 qqcs
(@qqcs)
I try to set parameters for  AC Vyper with 1mm nozzle
Almost everything is ok but the printer makes big gaps between the start and endpoint of the lines. Much bigger then visible in the slicer. test file
Questa discussione è stata modificata 4 years fa da qqcs
Postato : 17/02/2022 2:08 pm
Robin
(@robin)
I think you need to optimize your retraction settings. It looks like there is no filament extruding when the extruder already moves after deretraction. You have 6.5 mm set as retraction length, this seems a lot even for a bowden extruder. I suggest you try a little less retraction length, if this is not enough or you have some filament loss due to oozing you might try adding a little "extra length on restart" or reduce the temperature a bit to prevent that.
Postato : 17/02/2022 3:56 pm
qqcs
 qqcs
(@qqcs)
Thank you for your reply. Yes it is a bowden extruder, but the retraction setting worked well for 0.4mm nozzle. I even thought need bigger because 1 mm nozzle allows lot of filament and leave bumps many times when stops or changing direction
My first thought was a bug in a slicer. As you can see the prusa visualization looks almost ok but the real gcode also showed the gaps. I included now the gcode here: test gcode
Questo post è stato modificato 4 years fa da qqcs
Postato : 17/02/2022 5:05 pm
qqcs
 qqcs
(@qqcs)
RE: Is it a bug? Big gaps
I still dont have a solution 🙁
Postato : 20/02/2022 5:13 pm
qqcs
 qqcs
(@qqcs)
Postato : 21/02/2022 6:45 pm
AleCacko
(@alecacko)
did you find the solution to your problem? I think I have something similar
Postato : 02/03/2022 8:31 pm
Wolfgang Mauer
(@wolfgang-mauer)
Same here, seam gap is to big. .8mm Nozzle, .6mm Layerheight
Postato : 02/03/2022 10:02 pm
qqcs
 qqcs
(@qqcs)
No I didn't. I think this is a bug but I dont know how to report it.
Postato : 02/03/2022 10:51 pm
you can report bugs on the prusa slicer git hub page.
Postato : 03/03/2022 9:06 am
