I think you need to optimize your retraction settings. It looks like there is no filament extruding when the extruder already moves after deretraction. You have 6.5 mm set as retraction length, this seems a lot even for a bowden extruder. I suggest you try a little less retraction length, if this is not enough or you have some filament loss due to oozing you might try adding a little "extra length on restart" or reduce the temperature a bit to prevent that.
Thank you for your reply. Yes it is a bowden extruder, but the retraction setting worked well for 0.4mm nozzle. I even thought need bigger because 1 mm nozzle allows lot of filament and leave bumps many times when stops or changing direction
My first thought was a bug in a slicer. As you can see the prusa visualization looks almost ok but the real gcode also showed the gaps. I included now the gcode here: test gcode
RE: Is it a bug? Big gaps
I still dont have a solution 🙁
did you find the solution to your problem? I think I have something similar
Same here, seam gap is to big. .8mm Nozzle, .6mm Layerheight
No I didn't. I think this is a bug but I dont know how to report it.
you can report bugs on the prusa slicer git hub page.
