Installing Prusa Slicer 2.3.0 on PC without Internet connection
MK3Printer
(@mk3printer)
Hi!
I would like to install the new Slicer on a machine without the possibility to connect to the internet.
I tried to install the exe from USB-Stick but it tells me that it is not possible without a inet-connection.
Really?
How to get rid of this problem?
Thanks
Günther
Veröffentlicht : 17/01/2021 2:33 pm
RE: Installing Prusa Slicer 2.3.0 on PC without Internet connection
https://github.com/prusa3d/PrusaSlicer/issues/5790
rtyr mentions the normal installer doesn't require an internet connection but the stand alone one does.  SO try using the full drivers package instead.
Alternative you could just download Slicer from github, extract it to a folder of your choice and then just run the exe file.  No install required at all then.  It will even run from a thumb drive or similar.  It just stores all the profiles on the computer as normal. Just create a shortcut to the exe and run it or double click the exe directly to run.
Furthermore beyond that you can edit the start switches when you run the exe in which case you can choose where it stores all the profiles so its actually possible to also store them on the thumb drive too which gives a completely portable version that can be ran on any pc.
Veröffentlicht : 17/01/2021 8:10 pm
