Incorrect calculation when printing bridges
Knaz
 Knaz
(@knaz)
Hello! I found out that when printing a cube with dimensions 50x50x5 (mm) and a wall thickness of 1 mm, the bridge is not printed as it should be. The fault is that there is a contradiction in settings. As a result, a defect occurs. I do not know if this is a mistake or a flaw, or it should be so. But it would be nice for the program to recognize these collisions by itself.
Posted : 11/12/2020 4:00 am
Knaz
 Knaz
(@knaz)
RE: Incorrect calculation when printing bridges
Sorry forgot to describe the defect. When printing a bridge, the filament simply falls inside
Posted : 11/12/2020 8:38 am
marcottt
(@marcottt)
not understand... how big is that?  seem to not be a bridge and need support
Posted : 11/12/2020 1:10 pm
jsw
 jsw
(@jsw)
Large bridges do need support.  They will indeed sag.
There's an option in PrusaSlicer, which is checked by default, to not generate supports under bridges.  Un-checking this will generate the needed supports.
Posted : 11/12/2020 5:12 pm
Knaz
 Knaz
(@knaz)
The length of the bridge is 5 centimeters. This is a test model. Especially to expose the flaws in the program. The point is that with a thin wall, the slicer can print a bridge right on the void. Naturally, this leads to total failure.
Posted : 12/12/2020 12:52 pm
