Incomplete inner perimeter with 0.8 nozzle
Andreas Elias
(@andreas-elias)
Utenti
Hi, I am trying to fix an issue I've been having while trying to print PETG with a 0.8 nozzle. I am using prusaslicer 2.6 with my ender s1 pro and I did not find any parameter that could cause this travel move behavior. I activated the "staggered inner seam" option but without this option the issue persists. The xray of the gcode does not show any defects that I can see. I hope someone can shed some light on how I can address this issue. Thanks
Gap in the inner perimeter
Xray of the perimeter
Incomplete travel movement
Postato : 24/07/2023 3:10 am
Check the design is completely concentric - even a computed centre can be off due to rational approximation of non-binary precision.
A clue to this cause is when the issue moves. or sometimes is fixed, by slightly repositioning the part on the bed.
Postato : 24/07/2023 10:22 am
Andreas Elias
(@andreas-elias)
Utenti
RE: Incomplete inner perimeter with 0.8 nozzle
It shifts to where I place the seam so I doubt that is a problem related to the model. I activated the "staggered inner seam" option so it would not create a hole in the printed part, it kind of fixed the hole but it still makes the part fragile. I only noticed this problem when I started using the 0.8 nozzle, the 0.4 worked without any issues.
Postato : 24/07/2023 1:53 pm
Of course; with 0.4 there is room for four perimeters and four micro-alignments so the problem doesn't arise.
Postato : 25/07/2023 2:26 pm
