Improting mk3 config to suit mk4
Skywarp
(@skywarp)
I have upgraded my MK3S+ to a MK4.  I have a special config set up and perfectly tuned for TPU .  When I import this into Prusaslicer it sets it up for a MK3, how can I change this to suit the MK4 (as it was originally set up for a MK3) ? Do I only need to change the Z Height or do I need to change everything as it is physically a different printer
Publié : 02/08/2023 2:44 am
Robin
(@robin)
Well the MK4 has -as you know- a completely different hot end, so it would be a surprise if it runs with the exact same slicer settings. You will probably have to adjust a few things, z-height being not one of those (where would you change that in slicer anyway?).
You can remove the dependencies from print and filament settings and save them. Thereafter Slicer allows you to load and use them with any printer you like. Whether that's better than using default settings and optimize from there might be worth a try, depending on what filament you use and how many changes you made to the defaults.
Ce message a été modifié il y a 3 years par Robin
Publié : 02/08/2023 1:01 pm
