Importing configuration printer profiles for another machine?
RedBeard
(@redbeard)
Hello everyone,
   I have an older 3DP1000 large format printer from 3D PLATFORM, and I would like to try and use PrusaSlicer 2.0 with this machine. I am also a new owner of a Prusa I3MKS2 with an MMU2 addition and I like the PrusaSlicer, so I thought I would spread the love.
I found a older SLIC3R Configuration .ini file at 3D Platform here; https://3dplatform.com/documents-and-downloads/ .
How do you import these .ini configurations file to PrusaSlicer 2.0 so I can select a different machine?
Thanks
Wade
Opublikowany : 30/07/2019 5:43 pm
MisterBill
(@misterbill)
Did you ever come up with a 3DP1000 config for PrusaSlicer?
I'm in the same boat.  Was hoping you might be able to share what (if anything) you've found or developed for optimal 3DP1000 slicing with Prusaslicer.
-Bill
Opublikowany : 30/08/2021 1:46 pm
