Imported STL files are blank in PrusaSlicer
eriswerks
(@eriswerks)
I've recently been having an issue with my imported files being blank in PrusaSlicer 2.52. After choosing the file and clicking OK, the plater view remains totally empty. The STL shows up in the list, and if I slice it, the sliced results are visible and look as they should. However, them being invisible before slicing prevents me from plating them correctly.
This is happening with multiple files, all created in and exported from Fusion 360. PrusaSlicer opens some STL files fine, but others simply don't work. I've tried using the STL and OBJ formats, with the same results. I've tried using "repair STL file," no luck. The files open fine in Cura and look as expected.
I've included a link below to one of the files that's giving me the issue. I'm curious to hear if it imports normally for other people. Any suggestions would be appreciated!
example file
Este debate ha sido modificado el hace 3 years por eriswerks
Respondido : 10/06/2023 8:50 pm
3Delight
(@3delight)
Moderador Moderator
RE: Imported STL files are blank in PrusaSlicer
Hi, it loads fine for me in PrusaSlicer 2.6.0 rc1.
Respondido : 11/06/2023 5:20 pm
You are changing back to the plater view after slicing when loading new stls arent you ?  Bottom left corner, 2 icons that switch between plater and preview.  It doesnt automatically switch back on loading new files (yet).
Respondido : 11/06/2023 5:32 pm
