Import Configuration Settings from SuperSlicer into PrusaSlicer
d_man97
(@d_man97)
Is it possible to import my configuration settings from SuperSlicer into PrusaSlicer?  I tried to export a config bundle from SuperSlicer but when I import it to PrusaSlicer I get this error:
"Invalid configuration bundle "J:\Superslicer_config_bundle.ini", section [print0.20mm Normal @CREALITY - Copy]: invalid value provided for parameter external_permiter_extrusion_width:
When I went to check on the extrusion width settings I noticed it is under Width & Flow in SuperSlicer and Advanced in PrusaSlicer.  I also noticed that SuperSlicer has an extra setting for spacing which PrusaSlicer does not have.
Do these differences prevent me from importing my configuration settings?
Best Answer by Neophyl:
You can not import the settings at this time.  While one is a fork of the other there are many extra options on the SuSi fork.  I doubt Prusa will ever add in code to allow the import back to PS.
Respondido : 18/02/2023 8:34 pm
RE: Import Configuration Settings from SuperSlicer into PrusaSlicer
Respondido : 18/02/2023 10:13 pm
