I would like to have my engraving less outlines than my outer walls
lovethepirk
(@lovethepirk)
Is there a way to make engraving less walls than the outer part walls?  If not, how would I make the first 3 layers of a part only 1 wall, and the remaining part 3 walls?
---the pic is from cura preview but shows how I do not like to have 3 outlines on text engraving
Opublikowany : 29/04/2023 1:27 am
RE: I would like to have my engraving less outlines than my outer walls
you could use a height range modifier, to change the number of perimeters to 1
Opublikowany : 29/04/2023 2:15 am
lovethepirk
(@lovethepirk)
AWESOME!!!  Thank you...you just sold me on prusa slicer.....this is the same as S3d's processes tab....Cura you have to do these goofy blockers.
Opublikowany : 29/04/2023 2:49 am
lovethepirk
(@lovethepirk)
I'm about 30 minutes into trying to get this to work and can't get it....I've been printing since we were using replicator G
Opublikowany : 29/04/2023 3:07 am
lovethepirk
(@lovethepirk)
here is the exact location where you have to create a new location....you should be able to right-click the layer icon to do this but you have to 'know' that you have to scroll down and click the plus sign below....
Opublikowany : 29/04/2023 3:22 am
