I have two almost exact models of a V-22 Osprey for my buddies kid
tiger20180
(@tiger20180)
Miembro
I made two almost identical V-22 Ospreys for a friends kid and for some reason the one without landing gear's tail doesn't want to slice properly.
Here is the model that works.
This is the one that doesn't want to work.
I cant figure out how to attach the .3mf's otherwise I would.
Respondido : 11/08/2025 2:53 pm
RE: I have two almost exact models of a V-22 Osprey for my buddies kid
to attach a .3mf file, you need to Zip compress the file and attach the ZIP file.
have you tried fixing the model with the windows algorythm, (assuming you are using windows)
is it possible that the vertical stabilisers are thinner on the second model?
this could cause problems.
if repair dosn't help, try incrasing XY Size Compensation, 0.2mm often helps, with a 0.4mm nozzle
Respondido : 11/08/2025 6:13 pm
tiger20180
(@tiger20180)
Miembro
I did use the windows repair and I will look into the xy. I will also reply with the file when I get back to my pc. Thank you
Respondido : 12/08/2025 1:18 pm
Cheers,
Joan
Respondido : 12/08/2025 1:39 pm
tiger20180
(@tiger20180)
Miembro
Thank you, that was the problem.
Respondido : 12/08/2025 7:51 pm
Glad to help
Respondido : 12/08/2025 8:55 pm
