RE: Huge problem with accepting cookies
It happened to me, and I was able to click on the buttons when I switched to the "Prusa Connect" tab, then the popup did not show up anymore when on the "Plater" tab
Opublikowany : 17/04/2025 8:14 pm
1 ludzie polubili
If you click on the Prusa Connect menu item (the one listed after printable, filament in the top menu), then click on the cookie option, you can then use the "Send to Connect" without the cookie pop-up coming up. 🙂
Opublikowany : 17/04/2025 8:16 pm
I have the same issue.
Opublikowany : 17/04/2025 10:18 pm
I was also very annoyed with this. The advice to go to the Prusa connect tab to make cookie selection, then back to platter tab to send the print to connect resolved it for me.
Opublikowany : 17/04/2025 11:45 pm
