How to start PrusaSlicer 2.9.2 on Linux
jens
 jens
(@jens-6)
This is probably a stupid question so my apologies in advance but ....
I had 2.9.2 rc2 installed (on Ubuntu). After installing 2.9.2 (final), whenever I click on the PS icon, the system starts RC2 instead of the final release. I unpinned the quick start button, started PS 2.9.2 (final), it starts just fine and then I tell it to pin the application .... seems fine .... but when I close PS and try to start it again via the pinned tab it loads 2.9.2 RC2 instead of the final version.
How can I start 2.9.2 (final) ???
Best Answer by _KaszpiR_:
try in the terminal some commands:
# run specific version of the app
flatpak run --branch=beta com.prusa3d.PrusaSlicer
flatpak run --branch=stable com.prusa3d.PrusaSlicer
# remove specific version that you do not want
flatpak remove com.prusa3d.PrusaSlicer
Similar installed refs found for ‘com.prusa3d.PrusaSlicer’:
   1) app/com.prusa3d.PrusaSlicer/x86_64/stable (system)
   2) app/com.prusa3d.PrusaSlicer/x86_64/beta (user)
   3) All of the above
Which do you want to use (0 to abort)? [0-3]: 2
# disable whole flatpak beta builds
flatpak remote-delete flathub-beta
Publié : 25/06/2025 11:04 pm
Walter Layher
(@walter-layher)
RE: How to start PrusaSlicer 2.9.2 on Linux
Use the editor for your start menu (gnome or kde) and create a new entry there with the correct path to your executable.
Publié : 26/06/2025 7:10 am
jens
 jens
(@jens-6)
The problem is that the proper start command according to the instructions is
flatpak run com.prusa3d.PrusaSlicer
but that starts the RC2 version instead of the the newly installed final release.
I have found that 'alacarte' can be used to edit the start menu (I do not know what to edit when you say 'edit the start menu' but even when I change the run command to what we are supposed to use, it starts RC2. I have unpinned  the quick start button for PS, started 2.9.2 (final) via the 'app details' option on the quick start button which then allows me to pin the new quick start button. When I close the current session and attempt to start a new session with the newly installed quick start button, I get the RC2 version starting up 🙁
Publié : 26/06/2025 11:23 pm
Flatpak is a truly horrible environment for the average user; are you using Flatseal to manage updates?
Publié : 27/06/2025 2:13 am
Walter Layher
(@walter-layher)
From what I can find this editor can deal with flatpak menu entries:
https://flathub.org/apps/page.codeberg.libre_menu_editor.LibreMenuEditor
I myself still have several old appimage versions of PrusaSlicer on my system and after they changed the format to flatpak I had some problems with file permissions and also the window sometimes stayed blank. Then I started to compile PrusaSlicer from source. The build instructions on github should work on linux systems that are close to Ubuntu which is the reference they give. I am on debian unstable. I find this less complicated than to figure out the intricacies of flatpaks. 🙂 And I don't have to wait for the flatpak maintainers to update the package.
Publié : 27/06/2025 8:54 am
jens
 jens
(@jens-6)
OMG, I have done the occasional compile here and there maybe 20 years ago but that is something I definitely do not wish to get involved with any more. It might be easy once a person gets used to it but this is definitely a mountain I do not wish to climb at my age.
Publié : 27/06/2025 12:11 pm
_KaszpiR_
(@_kaszpir_)
   3) All of the above
Publié : 27/06/2025 7:34 pm
_KaszpiR_
(@_kaszpir_)
also see https://help.prusa3d.com/article/install-prusaslicer_1903
Publié : 27/06/2025 7:39 pm
jens
 jens
(@jens-6)
Posted by: @_kaszpir_
   3) All of the above
Ding ding ding, we have a winner !!!! (mostly)
The option --branch=stable added to the original running instructions brings up the final release. I re-pinned the final version, closed it and opened it via the pinned shortcut ..... it started up RC2 again! However, now knowing how to actually run the final version, I started alacarte and modified the run command to include the --branch=stable command and now, when I click on the quick start icon, I get 2.9.2 (final). Wooohooo !!!!!   THANK YOU!
As a side note, IMHO there is a bug in the flatpak because if I run the final version of 2.9.2 and pin it, then the proper run commands should be set up in the pinned shortcut to run that final release.
Publié : 27/06/2025 7:59 pm
_KaszpiR_
(@_kaszpir_)
No, it's not a bug in the flatpak, or the window manager that you use, it's by design, you probably have a beta set as a default.
Try
flatpak make-current com.prusa3d.PrusaSlicer stable
Publié : 27/06/2025 8:07 pm
jens
 jens
(@jens-6)
Ok, I followed your suggestion just in case the issue comes up with the next release.
Thanks!
Publié : 27/06/2025 9:20 pm
Robin_13
(@robin_13)
Look hear for an appimage if you want that.  Proves that an appimage can be created for PrusaSlicer.  Currently at 2.9.2.
PrusaSlicer.AppImage
Publié : 05/07/2025 3:42 am
