How to slice object with lots of small connections to the bed
SammyV
(@sammyv)
Hi there.
I'm having no luck getting good slicing to get parts with lots of small bottom surfaces on the bed.  Stuff like this mini Octopus( https://www.thingiverse.com/thing:3495390) or this print in place engine ( https://www.thingiverse.com/thing:4575774).
I'll get a picture posted, but what happens is that while most of the bottom surfaces print, the ones at the far end of the print end up tearing off, likely when doing a layer change.  It's like the printer is moving too fast away from that end and rips it off the bed.
Things I've tried:
-slow down to 15mms/s for first layer.  Gets better here but, still fails
-increase print temp and bed temp to improve adhesion.  This improves a bit, but still fails.
-checked my bed level: leveled my bed manually as best I could, also using a BL touch.
All other prints with long continuous lines on the first layer come out just fine.
As I'm writing this, I realized that this may not be a PrusaSlicer problem.  So feel free to tell me to "take a hike" 🙂
Appreciate any tips.
Thanks
Opublikowany : 16/07/2021 4:58 pm
towlerg
(@towlerg)
A raft?
Opublikowany : 17/07/2021 9:31 am
Unfortunately your images don't work - this might be an issue with the new forum software...
You can comment/feedback here:
https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/new-updates-coming-to-the-prusa-community-forums/
Generally complex print-in-place mechanisms require a near perfect first layer.  Spend some time getting that right and you have a good chance of success.
This suggests you have spots of poor adhesion, the commonest cause is fingerprint grease:
So go take a hike - to the kitchen sink, and clean the print-sheet with dishwashing detergent (Dawn/Fairy) and plenty of HOT water, rinse well and dry with a fresh paper towel. Handle by the edges only.
If this is not enough revisit your first layer calibration.
Opublikowany : 17/07/2021 11:34 am
