How to silently install and uninstall PrusaSlicer?
Haik
 Haik
(@haik)
I have tried to silently install PrusaSlicer using the command below but it will show a progress window and open webpages.
prusa3d_win_2_3_0.exe /sp- /silent /norestart
I have tried to silently uninstall PrusaSlicer with a command below but the uninstaller will ask "Are you supre you want to completely remove PrusaSlicer and all of its components?".
"C:\Program Files\Prusa3D\unins000.exe" /sp- /silent /norestart
Napsal : 02/03/2021 2:33 pm
Haik
 Haik
(@haik)
Still not working
Any news on this problem?
Napsal : 25/08/2021 5:47 am
This is a user to user forum.  You need to post bug reports over at github for the Prusa Slicer project.
There seems to have been issues with that as I found at least 1 currently closed issue https://github.com/prusa3d/PrusaSlicer/issues/2804 and another one that was closed due to the creator not providing any of the required details https://github.com/prusa3d/PrusaSlicer/issues/4472
Napsal : 25/08/2021 6:02 am
Haik
 Haik
(@haik)
We decided not to deploy PrusaSlicer. Our plan was to use it with 300 students. The silent installer issue was reported on GitHub on on 23 Aug 2019 but was never fixed. Instead the reported issue was closed.
Napsal : 30/08/2021 12:26 pm
Jan Olejnik
(@jan-olejnik)
Member Admin
PrusaSlicer silent install
Posted by: @haik
Hello, I'm responsible for the PrusaSlicer installer. Please let me know what the package should install (PrusaSlicer, drivers, sample objects) and I will prepare a command line script for you.
Prusa Research - Content Manager
Napsal : 31/08/2021 8:04 am
2 lidem se líbí
Polybius
(@polybius)
Silent Install With Drivers
Hi, I would like to install silently including the drivers. I have it installing silently with "/exenoui /qb /norestart" but I still get a prompt to install the driver. Thanks!
Napsal : 01/09/2021 6:27 pm
Lumpy
(@lumpy)
PrusaSlicer silent , full install for deployment.
I too work as an IT admin in a school district. Could you please provide me with the proper way to silently install all of PrusaSlicer without any driver prompts or it attempting to open a web page when it completes. Thanks.
Napsal : 15/09/2021 5:28 pm
Haik
 Haik
(@haik)
Maybe in the future
Posted by: @jan-olejnik
Posted by: @haik
Hello. We decided not use Prusa but we may consider using it again in the future so silent install and uninstall could be handy.
Napsal : 15/09/2021 6:34 pm
Fisiflo
(@fisiflo)
RE: How to silently install and uninstall PrusaSlicer?
@jan-olejnik can you please send me a commandline to install the following things silently, because when I use the normal parameters e.g. /VERYSILENT /SUPPRESSMSGBOXES than there comes up a dialogbox, where I should choose the language.
1. prusa3d_win_2_3_3 --> totally silent, German, including drivers
2. prusa3d_win_2_3_3 --> totally silent, German, not including drivers
3. prusa3d_win_2_3_3 --> totally silent, English, not including drivers
 Thanks in advance.
Kind regards,
Flo
Napsal : 06/12/2021 11:36 am
Sam
 Sam
(@sam-10)
I'm looking to silenty install the slicer and drivers for wide scale deployment, would you be able to build a command line for this?
Napsal : 12/01/2022 1:33 pm
amac
 amac
(@amac)
Can install strings still be created?  I tried prusa3d_win_2_5_0.exe /verysilent /exenoui /exenoupdates / quiet /qn and it still shows a gui.  I will be pushing this as part of an SCCM application so it needs to be the full package with drivers and silent.  Can you help me?  Its software version 2.5.0
Napsal : 04/10/2022 3:37 pm
Romio
(@romio)
I used /qn for a silent install
Napsal : 28/10/2022 12:17 pm
frwhite867
(@frwhite867)
Any news on when the installer will be fixed? I need to deploy 2.5.0 with driver silently and the silent options still don't work.
Napsal : 13/02/2023 12:59 pm
Haik
 Haik
(@haik)
Posted by: @haik
I got new request to install Prusa Silcer to 300 laptops. I said NO!
Napsal : 01/03/2023 11:51 am
frwhite867
(@frwhite867)
Must be nice to have that power. As of now I will have to do manual installs on any devices it needs to be on. Thankfully there are one 3 of them right now.
Napsal : 01/03/2023 1:19 pm
Jirka
(@jirka-3)
Hello. I'm working as MECM admin and I have a workaround to fully automate installation of Prusa 3D including all drivers and samples.
(I spend one day to figure it out 🙂 - I'm the person, who will never give up easily 🙂 and my colleagues really needed this to be done).
1. Install prusa 3D on test computer (tested was version 2.5.2 on Windows 10 22H2). You will have to select complete install including all drivers. This is necessary.
2. From folder, where You install Prusa 3D (default is: C:\Program Files\Prusa3D), select directory "Rambo" and copy directory and entire content to directory, where the source installer is at Your MECM fileshare.
3. Create Install.cmd at the same directory, where installer of Prusa3D is located and insert content below:
@echo offpushd %~dp0
"prusa3d_win_2_5_2.exe" /SILENT /TYPE=Custom /Lang=Czech /Components=prusaslicer,utilities,mk2objects,mk2mmobjects,mk3objects,mk3mmu2objects,mk3mmu2sobjects,mk25mmu2objects,mk25mmu2sobjects,miniobjects,sl1objects,sl1sobjects,xlobjects,mk4objects,pronterface /SUPPRESSMSGBOXES /NOCANCEL /NORESTART /SP-if exist "%ProgramFiles%\Prusa3D" xcopy /E/H/C/I "Rambo" "%ProgramFiles%\Prusa3D\Rambo"if exist "%ProgramFiles%\Prusa3D\Rambo" "%ProgramFiles%\Prusa3D\Rambo\dpinstx64.exe" /a /s
popd
timeout /T 5 /nobreak
4. Create UnInstall.cmd in the same directory, where Prusa3D installer is located with content below:
taskkill /IM prusa-slicer.exe /F
if exist "%ProgramFiles%\Prusa3D\PrusaSlicer\unins000.exe" "%ProgramFiles%\Prusa3D\PrusaSlicer\unins000.exe" /SILENT /SUPPRESSMSGBOXES /NORESTARTtimeout /T 3 /nobreakif exist "%ProgramFiles%\Prusa3D\unins000.exe" "%ProgramFiles%\Prusa3D\unins000.exe" /SILENT /SUPPRESSMSGBOXES /NORESTARTtimeout /T 3 /nobreakif exist "%ProgramFiles%\Prusa3D\Rambo\dpinstx64.exe" "%ProgramFiles%\Prusa3D\Rambo\dpinstx64.exe" /q /u %SystemRoot%\System32\DriverStore\FileRepository\prusamk3mmu2.inf_amd64_6742c3b3de2e5325\prusamk3mmu2.inftimeout /T 3 /nobreakif exist "%ProgramFiles%\Prusa3D\Rambo\dpinstx64.exe" "%ProgramFiles%\Prusa3D\Rambo\dpinstx64.exe" /q /u %SystemRoot%\System32\DriverStore\FileRepository\rambo.inf_amd64_2ea9422580b91167\rambo.inftimeout /T 3 /nobreakif exist "%ProgramFiles%\Prusa3D\Rambo\dpinstx64.exe" "%ProgramFiles%\Prusa3D\Rambo\dpinstx64.exe" /q /u %SystemRoot%\System32\DriverStore\FileRepository\prusacw1.inf_amd64_9da9d3e9e43e12a6\prusacw1.inftimeout /T 3 /nobreakif exist "%ProgramFiles%\Prusa3D\Rambo\dpinstx64.exe" "%ProgramFiles%\Prusa3D\Rambo\dpinstx64.exe" /q /u %SystemRoot%\System32\DriverStore\FileRepository\prusamk3.inf_amd64_0d91410013ee81fd\prusamk3.inftimeout /T 3 /nobreakif exist "%ProgramFiles%\Prusa3D\Rambo\dpinstx64.exe" "%ProgramFiles%\Prusa3D\Rambo\dpinstx64.exe" /q /u %SystemRoot%\System32\DriverStore\FileRepository\prusamk2.inf_amd64_c2920aad7c14b45c\prusamk2.inftimeout /T 3 /nobreakif exist "%ProgramFiles%\Prusa3D" rmdir /Q /S "%ProgramFiles%\Prusa3D"
popd
5. Create application in MECM - Deployment Type Script. You can set in user experience visibility to normal. Users will see, whats happening, but "cancel" is disabled.
Installer and Uninstaller are two .cmd scripts, which You created.
Detection method of installed app is: Registry - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Prusa3D_is1
Value: DisplayVersion, DataType: String, Equals: 2.5.2
6. Thats It. You can try it at test colection in MECM.
Napsal : 19/05/2023 6:16 am
Haik
 Haik
(@haik)
I tested version 2.9.2 and silent install and uninstall worked.
Prusa3d_win_2_9_2.exe /verysilent /norestart
"C:\Program Files\Prusa3D\PrusaSlicer\unins000.exe" /verysilent /norestart
Also Winget install works.
winget install Prusa3D.PrusaSlicer
Napsal : 01/07/2025 10:27 am
