How to remove solid infill
Berkley
(@berkley)
I am printing a three perimeter container and I can't find a way to remove the fuzzy solid infill. I found several topics on it and the solutions no longer work.
Not sure how to upload th 3mf file with my settings
Layers and perimeters
-Perimeters 3
-Solid layers: Top: 0
-Fill density 0%
-Skirt and brim: Brim width: 5mm
https://www.printables.com/model/108431-ananas-vase
PrusaSlicer 2.6.1+win64
Best Answer by JoanTabb:
Hi Berkley,
try this file...
It's set as vase mode, with an external perimeter extrusion width of 1mm  (your 0.4mm nozzle should be able to print this width)
Ananas JT
Opublikowany : 23/10/2023 2:01 am
RE: How to remove solid infill
zip compress the .3mf file, and attach the zip file
Opublikowany : 23/10/2023 9:32 am
Berkley
(@berkley)
Hi Joan,
See attached.
Ananas
Berkley
Opublikowany : 25/10/2023 9:57 pm
Hi Berkley,
try this file...
Ananas JT
Opublikowany : 25/10/2023 10:40 pm
Berkley
(@berkley)
Thank you Joan, that's a very innovative way to get rid of it. Might look at a .6 nozzle to make these even better.
Appreciate your help.
Berkley
Opublikowany : 31/10/2023 12:37 am
