How to remove filament color override?
ScoobyDoo27
(@scoobydoo27)
So I'm starting to calibrate all my filaments for the extrusion multiplier and when doing that I also tell the slicer the color of the filament. However, I used to just use the generic PLA profile and then override the color so it would show the color I was using. Now, I don't know how to clear that override so it just uses the color of the filament profile I'm using. Any help? I attached an image to show what I mean if it wasn't explained clear enough.
Publié : 10/01/2024 11:12 pm
ScoobyDoo27
(@scoobydoo27)
RE: How to remove filament color override?
I found the solution to my own question today and wanted to post it just in case someone else down the road finds this. Go to the printer settings tab then click on extruder 1 (or 2, 3, 4, etc. if using more than one extruder), then under the preview section you click "reset to filament color" (see attached image). Hope this helps anyone who may be looking in the future.
Publié : 11/01/2024 8:19 pm
