How to print to serial port?
PickyBiker
(@pickybiker)
I am trying to upgrade from Matter Control to PrusaSlicer 2.2.0 Final.
I can send gcode to an SD card, but I have not found a way to send prints directly to an attached printer.
Is that supported in PrusaSlicer?
Best Answer by karl-herbert:
I would also recommend a server solution such as Octoprint or alternatively a Wlan SD card. A direct connection PC-Printer is due to many possible interrupt requests too unstable for printing.
But the topic has been discussed many times in the forum: https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/printing-over-usb/
Postato : 03/01/2021 7:12 pm
Lichtjaeger
(@lichtjaeger)
RE: How to print to serial port?
No.
Postato : 03/01/2021 7:20 pm
Milos V.
(@milos-v)
You have to use Octoprint in between. PrusaSlicer can send gcode to OctoPrint server.
Postato : 04/01/2021 8:34 am
towlerg
(@towlerg)
Even if you could, it'd be a really bad idea. The PC would be dedicated to streaming GCode to your printer and as Windows (and Linux?) isn't a real time operating system good luck with that.
Postato : 04/01/2021 9:54 am
Postato : 04/01/2021 10:29 am
PickyBiker
(@pickybiker)
Thank you everyone!
Postato : 04/01/2021 2:17 pm
